Acre to Cuerda Converter
Easily convert acres to cuerdas. Learn the 1:1.02963 Puerto Rican land mapping formula, historical background, and view quick reference conversion tables.
Area Converter
Acre ↔ Cuerda (Puerto Rican Land Unit)
The Formula
Converting acres to cuerdas bridges standard US Customary measurements with traditional Caribbean Spanish land units. Since one international acre is defined as 43,560 square feet and a Puerto Rican survey cuerda is standardized to exactly 42,306.4264 square feet, an acre is roughly 3% larger than a cuerda.
Conversion Formula:
Cuerdas = Acres × 1.02963
If you are working in the opposite direction and need to turn cuerdas back into acres, you can multiply your total cuerda value by 0.97122 (or divide by 1.02963).
Acre to Cuerda Conversion Table
Use this reference table to evaluate regional plot sizes, farm boundaries, and property listings:
Acres (ac)Cuerdas (cda / cu)Approximate Square Footage
0.10 ac0.103 cda4,356 sq ft
0.50 ac (Half Acre)0.515 cda21,780 sq ft
1.00 ac1.030 cda43,560 sq ft
2.00 ac2.059 cda87,120 sq ft
5.00 ac5.148 cda217,800 sq ft
10.00 ac10.296 cda435,600 sq ft
50.00 ac51.482 cda2,178,000 sq ft
Contextual Information & Real Estate History
Though the standard metric system and US customary units dominate international commerce, regional surveying legacy units remain critical for localized mapping:
  • The Historical Concept: Similar to the ancient origin of the acre (which originally represented the amount of land a single man and a team of oxen could plow in one single day), the term cuerda translates to “cord” or “rope.” It originally defined a specific plot of land mapped out via standardized measurement ropes used by Spanish colonial surveyors.
  • Modern Legal Status: In Puerto Rico, while federal agencies use acres, almost all local real estate listings, legal deeds, property titles, and agricultural zoning registries track land area exclusively in cuerdas.
Why this matters for online tools: Providing an accurate acre-to-cuerda conversion utility helps appraisers, structural developers, and international real estate buyers seamlessly analyze property maps without running into calculation friction. Because the two units are so close in scale (1 vs 1.03), it is easy to misjudge property dimensions without utilizing the exact conversion factor.
Other Acres Conversion
