Easily convert acres to square poles (rods/perches). Learn the exact 1:160 imperial mapping formula, history of old survey tools, and view lookup tables.
Area Converter
Acre ↔ Square Pole
The Formula
Converting acres to square poles involves an exact mathematical relationship. Both of these metrics share a fixed definition within the traditional English Imperial and US Customary land measurement frameworks. One standard international acre contains precisely 160 square poles. To convert an area from acres to square poles, you multiply the total number of acres by 160.
Conversion Formula:
Square Poles = Acres × 160
Conversely, if you want to perform the reverse calculation to convert square poles back into standard acres, you divide your value by 160 (or multiply by 0.00625).
Acre to Square Pole Conversion Table
Use this reference table to see how typical agricultural plots and historical country subdivisions translate into square poles:
| Acres (ac) | Square Poles (sq pole) | Alternative Historical Names |
| 0.25 ac (Quarter Acre) | 40 sq poles | 40 Square Rods / 1 Rood |
| 0.50 ac (Half Acre) | 80 sq poles | 80 Square Perches |
| 1 ac | 160 sq poles | 160 Square Rods / Perches |
| 2 ac | 320 sq poles | 320 Square Rods |
| 5 ac | 800 sq poles | 800 Square Rods |
| 10 ac | 1,600 sq poles | 1,600 Square Rods |
Contextual Information & Land Surveying History
While the terms “pole,” “rod,” and “perch” sound completely different, they refer to the exact same physical size boundary in traditional surveying:
- The Linear Unit: Historically, a pole was a wooden measuring staff used by surveyors in medieval England. It was legally standardized to equal exactly 16.5 feet (or 5.5 yards).
- The Square Grid Matrix: A square pole measures 1 pole long by 1 pole wide ($16.5 \text{ ft} \times 16.5 \text{ ft}$), which equals exactly 272.25 square feet.
- The Acre Connection: Early agricultural land boundaries were plotted out based on what a plow team could manage. A standard acre (43,560 square feet) was configured to perfectly fit exactly 160 of these square pole blocks.
Modern Legal Applications: If you are evaluating older property abstracts, multi-generational family estate deeds, or historical land maps throughout New England, the United Kingdom, or legacy public records, you will frequently run across land boundaries outlined completely in poles, rods, or perches. Knowing this precise 160-to-1 conversion ratio ensures web tools, title abstractors, and developers can cleanly track legacy measurements into clean modern acreage descriptions.
Other Acres Conversion
- Acre to Square Centimeter Conversion
- Acre to Square Micrometer Conversion
- Acres to Square Miles
- Acres to Square Inches
- Acre to Square Hectometer
- Acre to Square Decimeter
- Acres to Ares Converter
- Acre to Square Mile (US Survey)
- Acre to Circular Inch
- Acre to Section
- Acre to Square Rod
- Acre to Square Perch
- Acre to Homestead
- Acre to Arpent
- Acre to Plaza
- Acre to Varas Conuqueras Cuad
- Acre to Square Kilometer
- Acre to Square Millimeter
- acres to hectare
- Acre to Square Yard
- Acre to Break
- Acre to Square Dekameter
- Acre to Square Nanometer
- Acre to Barn
- Acre to Square Foot (US Survey)
- Acre to Township
- Acre to Square Chain
- Acre to Square Pole
- Acre to Circular Mil
- Acre to Sabin
- Acre to Cuerda
- Acre to Varas Castellanas Cuad
- Acre to Electron Cross Section
- Acre to Rood
