Easily calculate the ideal carburetor CFM rating for your engine. Includes the standard CFM formula, an engine displacement reference chart, and key tuning tips.
Carburetor CFM Calculator
Enter your engine specifications below to find the ideal CFM (Cubic Feet per Minute) rating for your carburetor.
The Carburetor CFM Formula
Carburetor airflow is rated in Cubic Feet per Minute (CFM). The formula used to determine the CFM requirements of a standard four-stroke engine is as follows:
CFM = (Engine Displacement in CID × Max RPM × Volumetric Efficiency) ÷ 3456
Where:
- CID (Cubic Inch Displacement): The total volume of your engine’s cylinders. If you only know your engine size in liters (L), multiply the liters by 61.024 to convert to cubic inches (e.g., 5.0L × 61.024 ≈ 305 CID).
- Max RPM: The highest engine speed at which you intend to drive. Street cars rarely exceed 5,500 to 6,000 RPM, while race applications may go much higher.
- Volumetric Efficiency (VE): A measure of how well an engine draws air and fuel into its cylinders compared to its static volume. Standard street vehicles generally operate around 75% to 80% VE, high-performance street engines run at 80% to 85%, and dedicated race cars can reach 90% to 100% (or higher with supercharging).
Quick Reference CFM Table
The table below outlines approximate CFM requirements for common domestic engine sizes across different maximum RPM ranges, assuming a standard street-performance Volumetric Efficiency of 85%.
| Engine Size (CID) | @ 5,000 RPM | @ 5,500 RPM | @ 6,000 RPM | @ 6,500 RPM |
| 283 | 348 CFM | 383 CFM | 417 CFM | 452 CFM |
| 302 | 371 CFM | 408 CFM | 445 CFM | 483 CFM |
| 327 | 402 CFM | 442 CFM | 482 CFM | 523 CFM |
| 350 | 430 CFM | 474 CFM | 517 CFM | 560 CFM |
| 396 | 487 CFM | 536 CFM | 584 CFM | 633 CFM |
| 454 | 558 CFM | 614 CFM | 670 CFM | 726 CFM |
How to Choose the Right Carburetor Size
While calculating CFM yields a specific theoretical number, carburetor manufacturers produce units in standardized sizes (e.g., 500, 600, 650, 750, 850 CFM). Here is how to translate your mathematical calculation into the right physical carburetor:
1. Street vs. Track Applications
For street-driven vehicles, it is almost always better to choose a carburetor that is slightly smaller than the absolute maximum theoretical limit. A smaller carburetor increases intake air velocity, which improves throttle response, low-end torque, and drivability. For dedicated track or high-RPM drag racing vehicles, sizing slightly larger can help maximize high-end horsepower, though at the expense of low-speed responsiveness.
2. Vacuum Secondaries vs. Mechanical Secondaries
- Vacuum Secondaries: Highly recommended for street cars, heavy vehicles, or cars running automatic transmissions. The secondary barrels open progressively based on engine load, helping prevent engine “bogging” if you apply full throttle at a low RPM.
- Mechanical Secondaries (Double Pumpers): Better suited for lightweight cars, manual transmissions, and engines with deep rear-axle gearing. They open immediately when you press the pedal, demanding precise tuning to avoid fuel lag.
3. The Pitfall of Over-Carbureting
One of the most common mistakes in performance tuning is installing a carburetor that is too large (e.g., putting an 750 CFM carburetor on a mild 302 CID engine). This dramatically drops air velocity through the venturis, causing poor atomization of fuel, sluggish acceleration, high fuel consumption, and difficulty tuning the idle and transition circuits.
Automotive Calculator List
- Carburetor CFM Calculator
- Convert lb/hr to cc/min
- Convert cc/min to lb/hr
- Engine Compression Ratio Calculator
- Engine Displacement Calculator
- Engine Horsepower Calculator
- Engine Torque Calculator
- Electric Vehicle Charging Cost Calculator
- Electric Vehicle Charging Time Calculator
- Electric Vehicle Fuel Savings Calculator
- Fuel Cost Calculator
- Fuel Injector Flow Rate Calculator
- Fuel Savings Calculator
- Gas Mileage Calculator
- Kilometers Per Liter Fuel Economy Calculator
- Liters Per 100 Kilometers Fuel Consumption Calculator
Unit Conversion Calculators
- Electric Car Efficiency Unit Conversions
- Fuel Economy Unit Conversions
- SAE to Metric Calculator
- Metric to Standard Calculator
- Speed Unit Conversions
- Torque Unit Conversions
Vehicle Loan Calculators
Wheels & Tires Calculators
