emerson commander sk fault codes
emerson commander sk fault codes – Troubleshoot your Emerson Commander SK drive with our updated 2026 fault code guide. Learn to read OU, OI.AC, and HF codes, view the trip log via CTSoft, and reset faults to minimize downtime.
The Emerson (now Nidec / Control Techniques) Commander SK is a compact, easy-to-use AC general-purpose drive. Unlike drives with full-text LCD screens, the Commander SK uses a simple LED display that flashes specific alphanumeric codes when a trip occurs (e.g., OU, OI.AC, HFxx).
This guide provides the most updated resources for 2026 to help you decipher these codes and get your motor running again safely.
Commander SK Fault Codes Reference Table
Below is the complete list of trip codes and “HF” (Hardware Fault) codes. Please refer to this table to match the flashing code on your drive’s display with the specific issue.
Fault Code and MeaningCause and Remedy
UV
DC bus under voltage
  • Low AC supply voltage.
  • Low DC bus voltage when supplied by an external DC power supply.
Check power supply voltage and connections.
OV
DC bus over voltage
  • Deceleration rate set too fast for the inertia of the machine.
  • Mechanical load driving the motor.
Increase deceleration ramp time or install braking resistor.
OI.AC**
Drive output instantaneous over current
  • Insufficient ramp times.
  • Phase to phase or phase to ground short circuit on the drives output.
  • Drive requires autotuning to the motor.
  • Check motor and motor cable for insulation resistance.
  • If motor or motor connections changed, re-autotune drive to motor.
OI.br**
Braking resistor instantaneous over current
  • Excessive braking current in braking resistor.
  • Braking resistor value too small.
Check braking resistor value and wiring.
O.SPd
Over speed
Excessive motor speed (typically caused by mechanical load driving the motor).
Check mechanical load and speed parameters.
tunE
Auto tune stopped before completion
Run command removed before autotune complete.
Restart autotune and maintain run command.
It.br
I2t on braking resistor
Excessive braking resistor energy.
Check braking cycle and resistor rating.
It.AC
I2t on drive output current
  • Excessive mechanical load.
  • High impedance phase to phase or phase to ground short circuit at drive output.
  • Drive requires re-autotuning to motor.
Reduce load or check motor tuning.
O.ht1
IGBT over heat based on drives thermal model
Overheat software thermal model.
Check for blocked vents or fan failure.
O.ht2
Over heat based on drives heatsink
Heatsink temperature exceeds allowable maximum.
Reduce ambient temperature or check cooling fans.
th
Motor thermistor trip
Excessive motor temperature.
Check motor cooling and load.
O.Ld1*
User +24V or digital output overload
Excessive load or short circuit on +24 V output.
Check wiring on user I/O terminals.
O.ht3
Drive over-heat based on thermal model
Check drive mounting and ventilation.
cL1
Analog input 1 current mode, current loss
Input current less than 3 mA when 4-20 or 20-4mA modes selected.
Check signal source and wiring.
SCL
Serial communications loss time-out
Loss of communication when drive is under remote control.
Check serial communication cables and master controller.
EEF
Internal drive EEPROM trip
Possible loss of parameter values.
Set default parameters (see Pr 29).
PH
Input phase imbalance or input phase loss
One of the input phases has become disconnected from the drive (applies to 200/400 V three phase drives only, not dual rated drives).
Check input power supply fuses and wiring.
rS
Failure to measure motors stator resistance
  • Motor too small for drive.
  • Motor cable disconnected during measurement.
Check motor rating and connections.
CL.bt
Trip initiated from the control word
Control word has initiated a trip.
Check remote control logic.
O.ht4
Power module rectifier over temperature
Power module rectifier temperature exceeds allowable maximum.
Check airflow and ambient temperature.
C.dAt
SmartStick data does not exist
New/empty SmartStick being read.
Program the SmartStick or use one with valid data.
C.Acc
SmartStick read/write fail
Bad connection or faulty SmartStick.
Re-seat SmartStick or replace it.
C.rtg
SmartStick/drive rating change
Already programmed SmartStick read by a drive of a different rating.
Use SmartStick compatible with drive rating.
O.cL
Overload on current loop input
Input current exceeds 25 mA.
Check analog input source.
HFxx trip
Hardware faults
Internal drive hardware fault.
See Commander SK Advanced User Guide.
OVL.d
I x t overload (I = current, t = time)
Motor current overload detected.
Reduce motor current (Load).
hot
Heatsink/IGBT temperature high
Drive thermal model limits approached.
Reduce ambient temperature or reduce motor current.
br.rS
Braking resistor overload
Braking resistor thermal limit approached.
See Menu 10 in the Commander SK Advanced User Guide.
AC.Lt
Drive is in current limit
Load requires more current than the limit set.
FAIL
Failed attempt to read stick
An attempt has been made to read the stick when the drive was not disabled or tripped, or the stick is read-only.
Ensure drive is disabled before reading SmartStick.
How to Read Commander SK Faults via CTSoft
While the LED keypad provides a basic 2-3 character trip code, connecting your PC to the drive using the CTSoft (or the newer Connect) software allows for deeper diagnostics.
  • Current Trip: The software dashboard clearly displays the active trip explanation, removing the guesswork from deciphering abbreviations like “It.AC”.
  • Trip Log (History): The Commander SK stores the last 10 trips in Parameters 10.20 through 10.29. You can view these via the software or by unlocking “Level 2” or “Level 3” access on the keypad to see the historical sequence of failures.
  • Status at Trip: Advanced diagnostics can freeze-frame data such as the DC bus voltage and motor current at the moment the trip occurred, helping you identify if a spike caused the issue.
General Troubleshooting Steps
Before performing a reset, ensure you check the following key areas:
  1. Check Input Voltage: For UU (Under Voltage) trips, ensure your AC supply is stable. For OU (Over Voltage), check if the deceleration ramp is too short for the load inertia.
  2. Inspect Motor/Cables: For OI.AC (Over Current) or OI.br (Braking Resistor Over Current), disconnect the motor and check for phase-to-phase or phase-to-ground shorts with a megger.
  3. Verify Cooling: For O.ht2 (Heatsink Over Temperature), ensure the drive’s internal fan is spinning and the cabinet vents are not blocked.
Q: What does an “HF” code mean (e.g., HF20, HF25)?
A: HF stands for Hardware Fault. These are critical internal failures (such as DSP communication errors or current sensor failures) that usually cannot be reset by the user. If a power cycle (turning power off for 5 minutes and back on) does not clear an HF code, the drive typically requires repair or replacement.
Q: How do I reset an Emerson Commander SK fault?
A: You can reset the drive using one of these methods:
  • Press the red Stop/Reset button on the keypad.
  • Toggle the Enable/Reset digital input (Terminal B4) from High to Low to High.
  • Send a reset command via the Serial Comms or Fieldbus interface.
Q: Why is my drive flashing “tunE”?
A: This is not a fault; it indicates the drive is attempting to perform an Auto-Tune. The drive requires a Run command to complete this process. If the run command is removed before completion, it may trip on tunE.
