f0001 fault in abb drive
Is your ABB VFD tripping on F0001? Learn how to diagnose and fix the Overcurrent fault on ACS550, ACS355, and ACS150 drives with our expert guide.
f0001 fault in abb drive indicates Overcurrent. This means that the the motor’s output current has exceeded the drive’s internal trip limit.
ABB VFD Troubleshooting: F0001
F0001 / 0001/Fault 1
Description: OVERCURRENT
On ABB drives such as the ACS550 and ACS355, the F0001 fault occurs when the output current exceeds the drive’s instantaneous trip limit. This is a critical protection feature designed to save the drive’s internal power transistors (IGBTs) from damage due to electrical or mechanical stress.
Primary Causes of F0001
  • Sudden Mechanical Load: A jam in the conveyor, pump, or machinery causes the motor to draw massive current instantly.
  • Acceleration Time Too Short: The drive is trying to push the motor to full speed faster than the inertia of the load allows.
  • Electrical Short Circuit: A short in the motor windings or the motor cable (Phase-to-Phase or Phase-to-Ground).
  • Incorrect Motor Data: The motor parameters in Group 99 (Nominal Current, Voltage, Speed) do not match the physical nameplate.
  • Oversized Motor: The motor connected is too large for the drive’s rated output capacity.
⚠️ SAFETY WARNING: Always disconnect power and wait for the capacitors to discharge (approx. 5 minutes) before inspecting motor wiring or terminals.
Step-by-Step Solutions
1. Check the Load and Machinery
Decouple the motor from the load and try to run it. If the drive runs fine without the load, the problem is mechanical. Check for jammed bearings, broken belts, or clogged pumps.
2. Inspect the Motor and Cable
Disconnect the motor cables from the drive terminals (U, V, W). Use a Megger to check the insulation resistance of the motor and cables. If you find a reading below 2MΩ, you likely have a short circuit.
3. Review Parameter Group 22 (Ramp Times)
If the fault occurs specifically during the start-up phase, your acceleration ramp is likely too fast. Increase Parameter 2202 (ACCELER TIME 1) to allow the motor more time to reach speed.
4. Verify Motor Nominal Values
Check Group 99 and ensure 9906 (Motor Nominal Current) is set exactly to the motor’s nameplate value. If this value is too low, the drive’s internal calculation for overcurrent will be overly sensitive.
Key Parameters to Review
ParameterNameRecommended Action
2202ACCELER TIME 1Increase value (e.g., from 3s to 10s).
9906MOTOR NOM CURRMatch motor nameplate Amps.
2003MAX CURRENTEnsure this limit is not set too low for the application.
Pro-Tip: If the F0001 fault occurs immediately upon pressing ‘Start’ even with the motor cables disconnected, the drive’s internal current sensor or IGBT module is likely damaged and requires repair.
