A582 in ABB ACS880 drive
[#20189]
Cause: Auxiliary fan not running comes when an auxiliary cooling fan (connected to the fan connectors on the control unit) is stuck or disconnected.
A582 warning in ABB ACS880 drive indicates that an auxiliary cooling fan is not running.This means the fan is either stuck, disconnected, or has failed.
Solution:
  1. Check the fan blades for any physical obstructions, such as dust, debris, or foreign objects that may be preventing it from rotating.
  2. Check the fan's power and signal connections. A loose or disconnected wire can cause the fan to stop and trigger the warning.
  3. Try to replace fan then check.
