Facing fault F07802 in siemens G120 PM240 drive
2 Users
(@neeraj)
Eminent Member
i am facing fault F07802 in siemens G120 PM240 drive and when i change same drive then this fault not coming. Please suggest how i correct this issue.
F07802 - Infeed or power unit not ready. After internal power ON command, infeed or drive does not ready signal. Since you are getting this frequently, I suggest you to check, if it occurs at particular time of day & at same time check the input line supply voltage of drive & compare it with value set in p0210.
