INVT DA200 Servo Drive Fault Codes List (2026)
INVT DA200 Servo Drive Fault Codes List (2026) – Complete reference list of INVT DA200 AC Servo Drive fault codes. Learn to troubleshoot encoder alarms (Er02), position deviation (Er22), and servo tuning errors.
The INVT DA200 (SV-DA200) is a high-performance AC servo drive designed for precision motion control in CNC machines, packaging lines, and robotics. Unlike standard frequency inverters, the DA200 operates in a closed loop with a motor encoder. Consequently, its fault codes (displayed as ErXX-X) often relate to position accuracy, feedback signal integrity, and control loop stability.
This guide provides the most updated reference data for 2026 to help you decipher these servo-specific errors and distinguish between a tuning issue and a hardware failure.
INVT DA200 Fault Codes Reference Table
Use the search bar in the table below to quickly find your specific error code.
Fault Code and MeaningCause and Remedy
Er01-0
IGBT fault
The actual output current exceeds the specified value.
1. Drive fault (drive circuit, IGBT fault).
2. Short circuit of motor cable U, V, W, or the motor cable is grounded or connected improperly.
3. Motor burn down.
4. Reverse sequence of U, V, W phase.
5. Parameters are inappropriate and cause system divergence.
6. ACC/DEC of start/stop process is too short.
7. Instantaneous load is too large.
  • Remove the motor cables and enable the drive, if the fault persists, replace the drive.
  • Check the motor cables and wiring.
  • Reduce the value of P0.10 and P0.11.
  • Commission the loop parameters to stabilize the system and reduce the value of P0.12.
  • Increase the ACC/DEC time.
  • Replace with the drive with larger power.
  • Replace the motor.
Er01-1
Brake tube fault (7.5kW and above models)
Brake unit fault.
  • Replace the drive.
Er02-0
Encoder fault– The encoder cable broken
1. The encoder is not connected.
2. The encoder connector becomes loose.
3. One of U, V, W, A, B, Z phase cables is broken.
4. Reversed A/B phase of the encoder.
5. Communication break or abnormal data caused by noise.
6. Normal encoder communication but abnormal communication data.
7. FPGA communication overtime.
8. The drive does not support the encoder type.
  • Check the encoder connector or replace the encoder cable if the cable is disconnected.
  • Detect whether encoder power voltage is normal.
  • Reduce the interference of the encoder, route the encoder and motor independently and connect the shielded cables of the encoder to FG.
  • If reporting encoder disconnection fault when power on, check whether the available drive encoder type is consistent with the available motor encoder type according to P0.01.
Er02-1
Encoder fault–Encoder feedback error is too large
(Refer to Er02-0 Causes)
Common issues: Encoder connection, noise, or phase reversal.
  • Check encoder connections and shielding.
  • See detailed steps in Er02-0.
Er02-2
Encoder fault– Parity error
Communication interference or cable fault.
  • Check encoder cable continuity.
  • Improve shielding/grounding (Connect to FG).
Er02-3
Encoder fault–CRC check error
Communication interference or abnormal data.
  • Check grounding and cable routing.
  • Ensure encoder cable is not running parallel to power cables.
Er02-4
Encoder fault–Frame error
Encoder communication abnormal.
  • Check connector tightness.
  • Check for noise interference.
Er02-5
Encoder fault–Short frame error
Data packet incomplete or noise.
  • Verify cable integrity.
  • Check power supply voltage to encoder.
Er02-6
Encoder fault– Encoder overtime
Communication timeout.
  • Check if encoder is compatible with drive.
  • Check connections.
Er02-7
Encoder fault –FPGA overtime
Internal communication timeout or encoder failure.
  • Restart drive.
  • Check encoder and cable.
Er02-8
Encoder fault –Low voltage alarm of the encoder
If multi-turn encoder is used, the battery voltage of the external encoder is between 3.0V–3.2V.
  • Check the battery connection in encoder cable.
  • Check whether the external battery voltage of encoder is below 3.2V, if yes, change the battery.
  • Change the battery when the drive is power on; otherwise the encoder data will be lost.
Er02-9
Encoder fault –Undervoltage alarm of the encoder battery
If multi-turn encoder is used, the battery voltage of the external encoder is between 2.5V–3.0V.
  • Check the battery connection in the encoder cable.
  • Check whether the voltage is below 3.0V, if yes, change the battery.
Er02-a
Encoder fault –Encoder over-temperature
The feedback encoder temperature is higher than the set over-temperature value.
  • Check the setting value of the over-temperature protection value.
  • Stop the motor and reduce the encoder temperature.
Er02-b
Encoder fault– EEPROM write-in error
If the motor is used with communication encoder, and when the drive updates the data to encoder EEPROM, there is communication transmission error or data check error.
  • Check the encoder connection and reduce the interference to encoder communication.
  • Write in for several times or change the motor.
Er02-c
Encoder fault– EEPROM no data
If the motor is used with communication encoder, and when read encoder EEPROM during power on, there is no data.
  • Select the current motor model through P0.00 and then carry out the encoder EEPROM writing through P4.97.
  • Block the fault by P4.98, and then carry out corresponding initialization with the motor parameters in EEPROM.
Er02-d
Encoder fault– EEPROM data check error
If the motor is used with communication encoder, and when read encoder EEPROM during power on, there is data check error.
  • Check the encoder connection and reduce the encoder interference.
  • Shield the fault by P4.98, and then carry out corresponding initialization to the motor parameters.
Er03-0
Current sensor fault–U phase current sensor fault
1. Current sensor or abnormal detection circuit.
2. Power on when the motor shaft is in a state of non-stationary.
  • Repower on when the motor is in static state.
  • Change the drive.
Er03-1
Current sensor fault–V phase current sensor fault
Er03-2
Current sensor fault–W phase current sensor fault
Er04-0
System initialization fault
The self-inspection is not passed after initialization.
  • Repower on.
  • If the fault occurs for several times, change the drive.
Er05-1
Setting fault– Motor model does not exist
Wrong P0.00 setting.
  • Ensure the motor model is set correctly.
  • Ensure the motor parameter model matches with the power class of the drive.
Er05-2
Setting fault–Motor and drive model does not match
Wrong P0.00 setting (Model mismatch).
Er05-3
Setting fault– Software limit setting error
Software limit values setting is improper. The setting value of P0.35 is less than or equal to the setting value of P0.36.
  • Reset P0.35 and P0.36.
Er05-4
Setting fault–return to homing mode setting fault
Mode of P5.10 is set incorrectly.
  • Set P5.10 according to the instructions.
Er05-5
Setting fault– Point control travel overflow fault
The signal increment of idle travel of the bit exceeds 231-1.
  • The single travel cannot exceed 231-1 in the absolute position mode.
Er07-0
Regeneration of discharge overload fault
1. The power of the built-in braking resistor is relatively low.
2. The motor speed is too high or the deceleration is too fast.
3. The action limit of the external braking resistor is restricted to 10% of the duty ratio.
  • Replace with an external braking resistor and increase the power.
  • Modify the deceleration time and reduce regeneration discharge action rate.
  • Reduce the motor speed.
  • Improve the capacity of the motor and drive.
Er08-0
Analog input overvoltage fault– Analog input 1
The voltage inputted to analog input 1 port exceeds the setting value of P3.22.
  • Set P3.22, P3.25, P3.75 correctly.
  • Check the terminals wiring.
  • Set P3.22, P3.25, P3.75 to 0 to disable the protection function.
Er08-1
Analog input overvoltage fault– Analog input 2
The voltage inputted to analog input 2 port exceeds the setting value of P3.25.
  • Disable protection if needed.
Er08-2
Analog input overvoltage fault– Analog input 3
The voltage inputted to analog input 3 port exceeds the setting value of P3.75.
Er09-0
EEPROM fault– Read-write fault
1. The data stored in data storage area is damaged when reading data from EEPROM.
2. There is interference to EEPROM write operation.
  • Try again after repower on.
  • If the problem reoccurs for many times, change the drive.
Er09-1
EEPROM fault– data check fault
1. The data read from EEPROM when power on is different from that during writing.
2. The drive DSP software version updates.
  • Reset all parameters.
Er10-0
Hardware fault– FPGA fault
FPGA chip fault.
  • Repower on.
Er10-1
Hardware fault– Communication card fault
External communication card fault.
  • Repower on.
  • If the problem reoccurs for many times, change the communication card.
Er10-2
Hardware fault– Ground short circuit fault
During the earth test after power on, one of motor cables V, W is short-circuited to the ground.
  • Check the connection of the motor cables.
  • Change the motor cable or test whether the motor insulation aging or not.
Er10-3
Hardware fault– External input fault
This fault occurs when the digital terminal configured as external fault input function acts.
  • Clear the external fault input and enable fault clearance.
  • Repower on the drive.
Er10-4
Hardware fault–Emergency stop fault
This fault occurs when the digital terminal configured as emergency stop button acts.
  • Clear the emergency stop input and enable fault clearance.
Er10-5
Hardware fault– 485 communication fault
Strong EMI of 485 communication circuit causes drive serial communication alarms.
  • Use twisted shielded pairs for 485 communication.
  • Wiring communication cables and motor power cables separately.
Er11-0
Software fault– Reentry of motor control mission
1. CPU loading ratio is too high.
2. DSP software fault.
3. Illegal operation (Er11-2).
  • Reduce the software function.
  • Contact the customer service and change the DSP software.
Er11-1
Software fault– Reentry of cycle mission
Er11-2
Software fault – Illegal operation
Er12-0
IO fault– Digital input distribution repeated
Two or more digital inputs are configured to the same functions.
  • Reset P3.00–P3.09 and ensure there is no repeated setting.
Er12-1
IO fault–Analog input distribution repeated
If the drive is standard, the analog input 3 is speed command.
  • Set P3.70 to other value.
Er12-2
IO fault–Pulse input frequency is too high
The pulse input frequency detected by the drive is higher than the designated value.
1. External input pulse signal frequency is too high.
2. Damage of internal drive pulse frequency detection circuit.
  • Reduce the external input pulse signal frequency.
  • Change the drive if fault occur when external input signal is normal.
Er13-0
Main circuit overvoltage fault
The DC voltage of the main circuit is higher than the designated value.
1. The grid voltage is too high.
2. No braking resistor or pipe during braking or the braking resistor is damaged.
3. DEC time is too short during the stopping.
4. The internal DC voltage test circuit is damaged.
  • Check whether the grid input voltage exceeds the allowed value.
  • Check whether the internal braking resistor is loose or damaged; check whether external braking resistor is damaged.
  • Enlarge the setting value of ACC/DEC time.
  • Monitor R0.07 when the drive is disabled, if it is abnormal and does not match with grid input voltage, change the drive.
Er13-1
Main circuit undervoltage fault
The DC voltage of the main circuit is less than the designated value.
1. The grid voltage is too low.
2. The buffer relay is not switched on.
3. The drive output power is too large.
  • Check whether the grid input voltage is lower than the allowed value.
  • Repower on, and check whether there is pull-in noise of the relay.
Er14-0
Control circuit undervoltage fault
Cause: The DC voltage of the control power is less than the designated value.
2. The internal control power DC voltage test circuit is damaged.
  • Monitor R0.08 when the drive is disabled. If it is abnormal and does not match with grid input voltage, change the drive.
Er17-0
Drive overload fault
Cause: Short-time load of the drive is too heavy.
  • Check if the load is too heavy causing drive overload.
  • Check whether phase dislocation or phase loss occurred to UVW wiring of the motor.
  • Check whether encoder wiring is correct.
  • Check whether the motor is compatible with the drive.
Er18-0
Motor overload fault
1. Long-term overload running.
2. The load is too heavy during short time.
  • Replace with a drive and motor with larger power.
Er18-1
Motor overtemperature fault
Cause: Motor temperature exceeds the protection value.
  • Replace with a motor of larger power.
Er19-0
Speed fault – Overspeed fault
Cause: The absolute value of the motor speed exceeds the setting value of P4.32.
1. U, V, W phases of the motor are connected reversely.
2. Incorrect setting of the electronic gear ratio or motor speed loop control parameters.
3. The setting value of P4.32 is less than the setting value of P4.31 (max. speed limit).
4. Interference to the encoder feedback signal.
  • Check the electronic gear ratio.
  • Check the setting of speed loop control parameters.
  • Check that the phase sequence of the motor cable is connected correctly.
  • Check whether motor encoder connection is proper.
  • Replace with a motor with higher rotation speed.
Er19-1
Speed fault-FWD overspeed fault
Cause: Speed feedback exceeds the value of P4.40 by more than 20ms.
  • Check whether encoder is normal.
  • Check whether P4.40 parameter is set properly.
Er19-2
Speed fault-REV overspeed fault
Cause: Speed feedback exceeds the value of P4.41 by more than 20ms.
  • Check whether P4.41 is set properly.
Er19-3
Speed fault-Overspeed parameter setup is wrong
Cause: The value of P4.40 is less than 0 or P4.41 is larger than 0.
  • Check whether encoder is connected reliably.
  • Check whether P4.40 and P4.41 are set properly.
Er20-0
Speed deviation fault
Cause: In non-torque mode, the deviation between motor speed and speed command exceeds the set value of P4.39.
1. U, V, W phases connected reversely or cable not connected.
2. Motor load is so heavy it causes stall.
3. Insufficient drive force causing stall.
4. Speed loop parameters improper.
5. P4.39 value too small.
  • Check phase sequence of motor cable and ensure right wiring.
  • Check whether conveyer/chain/workbench reaches boundary or encounters obstacles.
  • Check loop control parameters or if drive is damaged/servo model is proper.
  • Enlarge the setting value of P4.39.
  • Set P4.39 to 0 to disable speed deviation fault detection.
Er21-0
Position overtravel-FWD overtravel
Cause: Under position mode, the FWD limit switch is touched or the accumulated feedback pulse exceeds P0.35.
  • Check whether FWD limit switch signal is correct.
  • Check whether P0.35 is set properly.
Er21-1
Position overtravel-REV overtravel
Cause: Under position mode, the REV limit switch is touched or the accumulated feedback pulse exceeds P0.36.
  • Check whether REV limit switch signal is correct.
  • Check whether P0.36 is set properly.
Er22-0
Hybrid control deviation is too large
1. Server response time too slow (retention pulse > P4.33).
2. Motor load too heavy causing stall.
3. Pulse input frequency too high (exceeds max speed).
4. Position command input step change > P4.33.
  • Enlarge position loop gain parameters, speed feedforward gain, or P4.33.
  • Adjust the electronic gear ratio parameter.
  • Decrease the variation of position command input.
Er22-1
Position increment overflow fault
Cause: In fully-closed loop control, the deviation between feedback position of linear encoder and that of the encoder exceeds P4.64.
  • Check the connection between the motor and load.
  • Check the connection between linear encoder and the drive.
  • Check the setting of P4.60, P4.61 and P4.62.
Er22-2
Cause: The position command of single variation after converting via electronic gear ratio exceeds (2^31 – 1).
  • Decrease the single variation quantity of position command.
  • Modify the gear ratio to a proper range.
Er23-0
Drive over-temperature fault
1. Ambient temperature exceeds designated value.
2. Drive overload.
  • Reduce the ambient temperature and improve ventilation.
  • Replace with a servo system with larger power.
  • Prolong the ACC/DEC time and reduce the load.
Er25-4
Application fault–Encoder offset angle test failed
Cause: Abnormity occurred during encoder offset angle test.
  • Check whether the motor shaft can rotate freely, then repower on and carry out.
Er25-5
Cause: The current feedback wave fluctuate violently during encoder offset angle test.
  • Reduce P4.53 parameter setting, then repower on and carry out.
Er25-6
Application fault–Offside of homing
Cause: Encounter the limit switch or software limit during homing.
  • Modify the setting of P5.10, repower on and carry out.
Er25-7
Application fault–Inertia identification failed
1. Vibration in stopping exceeds 3.5s.
2. Too short ACC time.
3. The identification speed is below 150r/min.
  • Improve the mechanical rigidity properly.
  • Increase P1.07.
  • Increase P1.06.
Er22-3
Sync signal overtime (CANopen)
Cause: Under interpolation position mode, time interval between two sync frame signals exceeds twice the communication time cycle.
  • Check communication cable to improve communication reliability.
  • Check whether the generation interval of sync frame of sync signal generation source is correct.
Er22-4
Position command buffer is full
Cause: CANopen PTP position command buffer is full.
  • Prolong the time interval of PTP position command transmission.
Er26-0
CANOpen disconnection
Cause: The master does not receive the heartbeat message from the slave during a period of time.
  • Check the communication wiring.
Er26-1
SDO index does not exist
Cause: SDO read or write parameters, the corresponding index does not exist or is not supported.
  • Check the index and modify EDS file.
Er26-2
SDO sub index does not exist
Cause: SDO read or write parameters, the corresponding sub index does not exist or is not supported.
Er26-3
SDO data length error
Cause: The length of SDO read or write command does not match with the data length in drive object dictionary.
  • Adjust the length of SDO R/W command according to the data length of drive object dictionary.
Er26-4
SDO write data exceeds the range
Cause: The range of SDO write command exceeds the data range of drive object dictionary.
  • Adjust written data of SDO according to the data range in object dictionary.
Er26-5
Read-only and non-modifiable error
Cause: Modify the read-only parameters.
  • Check whether the parameter to be written is read-only data.
Er26-6
PDO mapping length error
Cause: The mapping length of PDO data exceed 64 bit.
  • Check the mapping length of PDO.
Er26-7
PDO mapping data does not exist
Cause: PDO mapping data cannot be found in the object dictionary.
  • Check PDO mapping data in the object dictionary.
Er26-8
PDO not allowed to be changed in the operating
Cause: Modify the PDO mapping during operation.
  • Switch CANOpen state to pre-workbench and then modify PDO mapping.
Er26-9
PDO not allow the mapping
Cause: Map the parameters not allowed into PDO.
  • Check whether there are read-only PDO parameters being mapped into RPDO.
Er26-a
Sync signal is too fast
Cause: The received frame exceeds the range allowed by baud rate.
  • Modify the interval of data frame transmission via master station or the interval of synchronization frame.
  • Modify communication baud rate.
Er26-b
Receiving fault
Cause: CAN communication offline or the received error exceed 128.
  • Check communication wiring.
  • Restart the servo drive.
Er26-c
Transmission fault
Cause: CAN communication offline or received error exceed 128.
Er26-d
Sync signal repeat
Cause: Receive the synchronization signal of external input when synchronization signal is from slave station.
  • Modify the configuration and ensure only there is only one synchronization signal generation source in one communication network.
Er26-e
Bus load rate is too high
Cause: In asynchronous work mode, the number of frames received by the slave exceeds the scope allowed by baud rate.
  • Modify the interval of data frame transmission via master station.
  • Modify the transmission mode of slave station TPDO.
Er26-f
Parameter modification state error
Cause: Modify the parameter in the state not allowed.
  • Adjust the CANopen machine to Pre-OP or OP state, and then try to modify the parameters.
Er24-0
PWK ID error
Cause: PWK ID error.
  • Read the manual, ensure the ID of PWK corresponds to the parameter ID.
Er24-1
PWK exceed the range
Cause: The setting of PWK exceed the range allowed by the corresponding parameter.
  • Read the manual, ensure the PWK setting of PWK is in the range allowed by the corresponding parameter.
Er24-2
Read-only PWK parameter
Cause: PWK parameter performs write operation to read-only parameters.
  • Read the manual, ensure the parameter can be read and written.
Er24-3
PZD configuration parameter does not exist
Cause: The selected ID is not right.
  • Read the manual, ensure the ID corresponds to the corresponding parameter ID.
Er24-4
PZD configuration parameter does not matching
Cause: The parameter is not valid instantly.
  • Read the manual, ensure the parameter is valid instantly.
Er24-8
Initialization fault
Cause: Poor contact of EtherCAT chip.
  • Replace the servo.
Er24-9
EEPROM fault
Cause: EtherCAT EEPROM has no data or data reading failed.
  • Use TwinCAT tool to download xml file to EtherCAT EEPROM.
Er24-a
DC Sync0 signal abnormal
Cause: DC Sync0 interruption signal is not detected during a period of time under DC sync working mode.
  • Check whether interruption causes data loss.
  • Check whether EtherCAT master can work normally.
Er24-b
Disconnection fault
Cause: After the drive is enabled, the network cable is detected to be inserted improperly or EtherCAT master is running improperly.
  • Check whether network cable is connected properly (top-in and bottom-out).
  • Check interferences.
  • Check whether EtherCAT master can work properly.
Er24-c
PDO data loss fault
Cause: No PDO data is received after the drive is enabled for a period of time.
  • Check whether EtherCAT master works properly.
  • Check whether interference causes data loss.
Troubleshooting Common Servo Faults
The DA200 diagnostics are centered around the “Er” (Error) codes. The format is typically Er + Main Code + Sub Code (e.g., Er02-1).
  • Encoder Faults (Er02-X): These are the most common servo issues.
    • Er02-0 (Wire Break): The drive cannot see the encoder. Check the CN2 cable.
    • Er02-8 (Battery Low): For absolute encoders, this means the battery voltage is dropping below 3.0V. Replace the battery while the power is ON to avoid losing the absolute position data.
  • Position Deviation (Er22-0): This occurs in Position Mode when the motor cannot keep up with the command pulses from the PLC.
    • Mechanical Jam: Something is physically blocking the axis.
    • Gain Tuning: The “Position Loop Gain” is too low (motor is too “soft”). Increase the stiffness in the P1 parameter group.
  • Regenerative Overload (Er07-0): Common in vertical axes or fast stop/start applications. The internal braking resistor cannot dissipate the energy. You may need to install an external braking resistor and adjust parameter P0.15.
Q: What is the difference between “Er” codes and “AL” codes?
A: The INVT DA200 natively displays faults as ErXX-X. If you see AL-XX (Alarm), you might be looking at a specific HMI interpretation or a different brand of servo. However, within the DA200 software, some warnings (like Overload or Battery Low) act as alarms that allow the motor to continue running briefly before tripping.
Q: How do I fix “Er21-0” (Forward Limit Exceeded)?
A: This is a safety over-travel fault.
1. The axis has physically hit the Forward Limit Switch (connected to DI inputs).
2. To reset, you must switch the drive to “Manual/Jog” mode and move the motor in the Reverse direction to back off the switch.
Q: Why does the motor vibrate and then trip on “Er02-X”?
A: Vibration followed by an encoder fault usually indicates Noise Interference.
Fix:
1. Ensure the encoder cable is shielded and grounded at the drive end (FG).
2. Separate the encoder cable from the heavy motor power cable in the cable tray.
3. Check the ground connection of the motor frame.
