Quickly convert Microcoulombs (μC) to Coulombs (C). Includes the conversion formula, a quick reference table, and the definition of electrical charge units.
Microcoulomb to Coulomb Converter
Microcoulomb to Coulomb Formula
A Microcoulomb (μC) is a submultiple of the SI unit of electric charge, the Coulomb (C). The prefix “micro” signifies one-millionth (10-6). Therefore, converting between these units involves a factor of one million:
1 Microcoulomb (μC) = 0.000001 Coulombs (C)
To convert μC to C: Divide by 1,000,000
To convert C to μC: Multiply by 1,000,000
Conversion Quick Reference Table
Use this reference table for the most common charge conversions from microcoulombs to coulombs.
| Microcoulombs (μC) | Coulombs (C) |
| 1 μC | 1 × 10-6 C |
| 10 μC | 0.00001 C |
| 100 μC | 0.0001 C |
| 1,000 μC | 0.001 C (1 mC) |
| 1,000,000 μC | 1 C |
Understanding Electric Charge
The Coulomb (C) is the base unit of electric charge in the International System of Units (SI). It is defined as the charge transported by a constant current of one ampere in one second. Because a Coulomb represents a massive amount of charge (roughly 6.242 quintillion electrons), it is often too large for practical electronics.
The Microcoulomb (μC) is far more common in engineering. For instance, the charge stored in small ceramic or film capacitors is almost always measured in microcoulombs or even smaller units like nanocoulombs (nC).
Real-World Context:
- Static Electricity: When you rub a balloon on your hair, the static charge generated is typically in the range of 1 to 10 Microcoulombs.
- Capacitors: A typical 10μF capacitor charged to 5V holds exactly 50 Microcoulombs of charge.
- Lightning: A massive lightning bolt can carry between 1 and 20 Coulombs of charge, which is 1,000,000 to 20,000,000 Microcoulombs!
