Dealing with Fault F30001 on your Siemens SINAMICS G120 or S120? Learn how to diagnose overcurrent trips, check for short circuits, and verify power unit settings.
Siemens SINAMICS Fault F30001 indicates Overcurrent. This means the output current has exceeded the permissible limit, often caused by short circuits, incorrect motor data, improper ramp times, or motor/cable insulation issues.
Siemens SINAMICS Fault: F30001
F30001
Description: Power Unit Overcurrent
On the Siemens SINAMICS G120, S120, and G150 series, Fault F30001 is a hardware-level protection trip. It indicates that the Power Unit has detected an instantaneous current peak that exceeds the allowable limit. This is often caused by an external electrical fault but can also stem from improper drive configuration.
Top 5 Causes of F30001
- Short Circuit: A phase-to-phase or phase-to-ground short circuit in the motor cables or motor terminal box.
- Ground Fault: Insulation breakdown allowing current to leak to the earth.
- Motor Cable Length: The motor cable is too long, causing high capacitive charging currents that exceed the trip limit.
- Wrong Motor Data: Parameters (p0300 series) do not match the physical motor, leading to an unstable control loop.
- Power Unit Failure: The internal IGBTs or the current sensing circuit in the drive are damaged.
Troubleshooting Steps
1. Check Motor and Cable Insulation
Disconnect the motor cables from the drive. Use a Megger to test the insulation resistance between phases and to ground. If you find low resistance (under 10MΩ), the cable or motor is faulty.
2. The “No-Load” Test
Try running the drive without the motor connected.
- If F30001 persists: The Power Unit is likely damaged.
- If F30001 clears: The drive is healthy; the issue is with the load, motor, or cabling.
3. Review Acceleration Ramps
If the fault occurs only during startup, increase Acceleration time. A short ramp with a high-inertia load can cause a massive current spike.
4. Verify Pulse Frequency
If the pulse frequency is set too high for a long motor cable, the drive may trip. Try reducing it to see if the fault clears.
Critical Parameters to Check
| Parameter Description | Suggested Action |
| Rated Motor Current | Ensure it matches the nameplate exactly. |
| Acceleration Time | Increase if tripping during ramp-up. |
| Motor Identification | Run Standstill measurement to optimize the model. |
| Current Limit | Check if it is set too low for the starting torque required. |
If F30001 occurs immediately upon powering the drive (without a start command), it is almost always a hardware failure in the Power Unit. If it occurs during operation, focus on the motor, cables, and mechanical load.
