16: ERROR overload fault in KEB COMBIVERT R6 Drive
16: ERROR overload fault in KEB COMBIVERT R6 Drive indicates the actual load exceeded safe limits for too long. This means the load was greater than 105% and the internal overload timer timed out, forcing a protective trip.
Over Load; the actual load was greater than 105% and the overload timer timed out.
Reduce the load on the motor and drive.
