2: ERROR under voltage fault in KEB COMBIVERT R6 Drive indicates the DC bus voltage is too low. This means the incoming mains supply dropped significantly or a phase was lost, causing the internal DC voltage to fall below safe operating thresholds.
Under voltage; DC bus voltage is too low.
Verify incoming mains supply voltage levels.
