4: ERROR overcurrent fault in KEB COMBIVERT R6 Drive
4: ERROR overcurrent fault in KEB COMBIVERT R6 Drive indicates an excessively high output current. This means the drive detected a massive current spike, typically caused by a short circuit or a ground fault in the motor or cabling.
Over current; output current too high or ground fault.
Check the motor, cables, and power connections for ground faults or short circuits.
