A0098 alarm in WEG CFW701 Drive indicates an Activate General Enable warning. This means the drive’s automatic motor parameter identification process was halted prematurely by a disabled input command.
- The digital input programmed for “General Enable” is open.
Check the digital input assigned to keep the drive enabled during the self-tuning routine.
