A0110 fault in WEG CFW701 Drive
A0110 alarm in WEG CFW701 Drive indicates a High Motor Temperature. This means the motor’s PTC thermistor is warning that the motor is approaching its maximum safe operating temperature.
  • Excessive load at the motor shaft.
  • Severe duty cycle (too many starts / stops per minute).
  • Too high surrounding air temperature.
  • Not installed motor thermistors.
  • Blocked motor shaft.
Note: It can be disabled by setting parameter P0351 = 0 or 2. An analog input and an analog output must be set for the PTC function.
Check motor load and cooling. Verify that thermistors are installed and parameters are set.
