A0702 fault in WEG CFW500 Drive
A0702 alarm in WEG CFW500 Drive indicates the Inverter is Disabled. This means a SoftPLC movement block is attempting to execute, but the drive’s General Enable command is currently inactive.
  • The General Enable command for the drive is not active.
Check the drive control terminal states to ensure the General Enable input command is active.
