A0764 fault in WEG CFW500 Drive
A0764 alarm in WEG CFW500 Drive indicates the Frequency Inverter is in Sleep Mode. This means the PID controller has put the drive into a standby state because the process demand dropped below the configured sleep threshold.
  • The main PID controller is active in automatic mode, and the motor speed remained below the speed programmed in P1036 for the duration set in P1037.
Informational alarm status indicating sleep mode has engaged. To adjust this behavior, modify parameters P1036 (sleep speed) or P1037 (sleep delay time).
