A0764 alarm in WEG CFW701 Drive indicates the Frequency Inverter is in Sleep Mode. This means the PID controller has put the drive into a standby state because the process demand dropped below the configured sleep threshold.
- Main PID controller is enabled and in Automatic mode, and the motor speed is remaining below the speed value programmed in P1036 for the time programmed in P1037.
Informational alarm status indicating sleep mode has engaged. To adjust this behavior, modify parameters P1036 (sleep speed) or P1037 (sleep delay time).
