A0770 fault in WEG CFW500 Drive
A0770 alarm in WEG CFW500 Drive indicates Filter Maintenance is needed. This means the running hours of the system have exceeded the programmed threshold for filter replacement.
Parameter P1050 is programmed for 1, and the total motor operation time shown in P1052 is above the value programmed in P1051.
Perform scheduled maintenance to replace the system filter. Reset the elapsed timer if required.
