A1138 / F1139 fault in WEG CFW900 Drive
A1138 / F1139 Slot A temperature sensor 4 error fault in WEG CFW900 Drive
These codes indicate a Slot A Temperature Sensor 4 Error. This means the external sensor wire is broken or short-circuited.
  • Sensor 4 cable is broken.
  • Sensor 4 is short-circuited.
  • Sensor 4 is located in an extremely low temperature environment.
Check temperature sensor 4 cabling for open or short circuits. Verify that surrounding environmental temperatures are within system parameters.
