A1228 / F1229 Slot B sensor 1 high temp / overtemperature fault in WEG CFW900 Drive
These codes indicate a Slot B Sensor 1 High Temperature. This means the monitored external equipment has exceeded its safe thermal limits.
- The monitored equipment is operating at high temperature.
- Fault actuation level configuration error.
Verify equipment active operating temperature levels. Review parameter configurations for fault actuation thresholds.
