A1234 / F1235 Slot B temperature sensor 3 error fault in WEG CFW900 Drive
These codes indicate a Slot B Temperature Sensor 3 Error. This means the external sensor wire is broken or short-circuited.
- Sensor 3 cable is broken.
- Sensor 3 is short-circuited.
- Sensor 3 is located in an extremely low temperature environment.
Check temperature sensor 3 cabling for open or short circuits. Verify that surrounding environmental temperatures are within system parameters.
