A1426 / F1427 Slot D temperature sensor 1 error fault in WEG CFW900 Drive
These codes indicate a Slot D Temperature Sensor 1 Error. This means the external sensor wire is broken or short-circuited.
- Sensor 1 cable is broken.
- Sensor 1 is short-circuited.
- Sensor 1 is located in an extremely low temperature environment.
Check temperature sensor 1 cabling for open or short circuits. Verify that surrounding environmental temperatures are within system parameters.
