A1432 / F1433 fault in WEG CFW900 Drive
A1432 / F1433 Slot D sensor 2 high temp / overtemperature fault in WEG CFW900 Drive
These codes indicate a Slot D Sensor 2 High Temperature. This means the monitored external equipment has exceeded its safe thermal limits.
  • The monitored equipment is operating at high temperature.
  • Fault actuation level configuration error.
Verify equipment active operating temperature levels. Review parameter configurations for fault actuation thresholds.
