A1510 / F1511 fault in WEG CFW900 Drive
A1510 / F1511 Slot E enc. Z cable disconnection Encoder channel Z signal is not detected correctly. fault in WEG CFW900 Drive
These codes indicate a Slot E Encoder Channel Z Cable Disconnection. This means the drive lost the zero-marker reference signal from the encoder.
  • Broken or disconnected signal cable.
  • Encoder connection error.
  • Encoder has no power supply.
Verify the physical and electrical integrity of the encoder channel Z (marker) cabling. Check terminal connections and verify the encoder auxiliary power supply voltage.
