A702 alarm in WEG CFW900 Drive indicates the Inverter is Disabled. This means a SoftPLC movement block is attempting to execute, but the drive’s General Enable command is currently inactive.
Alarm indicates that the General Enable command is Inactive.
- Run/Stop command of the SoftPLC application equal to Run, or the movement block was enabled with the inverter in general disable.
Ensure the drive General Enable command is active. Check SoftPLC application logic parameters.
