A7480 fault in siemens sinamics V90 drive
A7480 alarm in siemens sinamics V90 drive indicates the EPOS Software limit switch plus was reached. This means the axis successfully stopped at the positive software boundary, interrupting its active traversing block.
Cause: The axis is at the position of the software limit switch plus. An active traversing block was interrupted.
  • Correct the target position.
  • Change software limit switch plus (CI: p2581).
