E.PUCI fault in KEB COMBIVERT F5 Drive
E.PUCI fault in KEB COMBIVERT F5 Drive indicates a Power Unit Invalid error. This means the drive’s control card could not correctly identify the power circuit during initialization, often due to electrical noise or poor connection.
Initialization recognition failure. This error could occur from electrical noise.
  • Disconnect the terminal strip, encoder cable, and serial communication (if used), then power cycle the drive.
  • Check phase-to-phase and phase-to-ground line voltages to make sure they are balanced and not causing noise.
  • Re-seat the ribbon cable connecting the control card to the power stage.
