E.Syn fault in KEB COMBIVERT R6 Drive
E.Syn fault in KEB COMBIVERT R6 Drive indicates a synchronization error. This means the line frequency was calculated incorrectly due to swapped or improper phasing at the commutation choke.
Line frequency calculated incorrectly.
If the value in CP.02 is negative, swap L1.1 and L2.1 at the commutation choke so that CP.02 is positive.
