F0079 fault in WEG CFW500 Drive
F0079 fault in WEG CFW500 Drive indicates an Encoder Signal Fault. This means the physical signal from the encoder has been lost completely, likely due to a broken wire or damaged sensor.
  • Wiring between encoder and the accessory interface encoder is broken or interrupted.
  • Defective encoder.
Check encoder cabling and connections. Swap encoder if defective.
