F0150 fault in WEG CFW701 Drive indicates a Motor Overspeed. This means the motor’s actual speed has exceeded the maximum programmed safety limit, potentially due to a loss of load control.
- Wrong settings of parameters P0161 and/or P0162.
- Problem with hoist-type loads (mechanical drag).
Note: It trips when the actual speed exceeds the value of P0134 x (100% + P0132) / 100% for more than 20 ms.
Check and adjust parameters P0161 and P0162. For hoist applications, ensure braking logic is aligned.
