F0157 fault in WEG CFW701 Drive indicates Parameter Table Data Loss. This means the drive failed to save recent parameter changes because it was powered down too quickly.
- The control was switched off very fast while a parameter was being modified.
Check parameter adjustments. Avoid powering down the control board immediately during configuration modifications.
