F0169 fault in WEG CFW500 Drive indicates the Speed Error is too High. This means the actual motor speed deviated significantly from the commanded speed for too long, indicating a stalled or bound motor.
- The inverter has operated in Torque Current Limitation mode for too long.
Check if the motor is stalled or heavily overloaded. Verify load status. If appropriate, adjust torque current limits in P0360 and verify parameter P0361.
