F0182 fault in WEG CFW500 Drive indicates a Pulse Feedback Fault. This means the internal circuitry detected a discrepancy in the output voltage pulses, possibly due to a hardware mismatch or defect.
- Hardware identification fault (compare P0295 and P0296 to the inverter identification label).
- Inverter internal pulse feedback circuit fault.
Note: This monitoring can be disabled in parameter P0397.
Verify parameters P0295/P0296 configurations match rating plate. Set P0397 to 0 to disable if required.
