F048 fault in WEG CFW900 Drive indicates an Overload on the IGBTs. This means the internal power transistors experienced sustained excessive current and tripped to prevent thermal damage.
- Current at the inverter output is too high.
Reduce motor load or duty cycle to prevent high output current. Verify inverter dimensioning.
