F054 fault in WEG CFW900 Drive
F054 fault in WEG CFW900 Drive indicates an IGBT1 V Overtemperature. This means the V-phase power module exceeded its safe thermal limits and the drive tripped to prevent hardware damage.
  • High ambient temperature around the inverter (>50 °C) and high output current.
  • Blocked or defective cooling fan.
  • Inverter heatsink is too dirty, preventing proper cooling airflow.
Check the ventilation/cooling fan. Clean the heatsink. Check ambient temperature.
