F0787 fault in WEG CFW500 Drive
F0787 fault in WEG CFW500 Drive indicates a Low Level of the External PID Process Variable. This means the external PID feedback sensor remained below the safe threshold, triggering a system fault.
Parameter P1075 is programmed for 2, and the process variable of the external PID controller remained below the value programmed in P1076 for the duration set in P1077.
Verify the process feedback loops and verify configurations in parameters P1075, P1076, and P1077.
