F099 fault in WEG CFW900 Drive indicates an Invalid Current Offset. This means the internal current sensors are reporting a false reading while idle, pointing to hardware damage.
Current measurement circuit has a value out of the standards for zero current.
- Defect on the inverter internal circuits.
Check the internal current sensors. Board replacement or factory repairs may be necessary.
