F1018 fault in Siemens V70 Drive
F1018 fault in Siemens V70 Drive indicates Booting has been interrupted several times. This means the drive failed to complete its startup sequence repeatedly, often due to power instability or corrupted parameters, and has booted with factory settings.
Cause: Module booting was interrupted several times. As a consequence, the module boots with the factory setting.
Possible reasons for booting being interrupted:
  • Power supply interrupted.
  • CPU crashed.
  • Parameterization invalid.
After this fault is output, then the module is booted with the factory settings.
  • Carry out a POWER ON (power off/on). After switching on, the module reboots from the valid parameterization (if available).
  • Restore the valid parameterization.
Examples:
  • Carry out a first commissioning, save, carry out a POWER ON (switch-off/switch-on).
  • Load another valid parameter backup (e.g. from the memory card), save, carry out a POWER ON (switch-off/switch-on).
Note: If the fault situation is repeated, then this fault is again output after several interrupted boots.
