F1100  fault in WEG CFW900 Drive
F1100 fault in WEG CFW900 Drive indicates a Slot A Incompatible Accessory. This means the expansion card installed in Slot A is not supported by the current drive firmware.
Error during accessory firmware update.
  • Old inverter firmware version.
Update the inverter base firmware to support the accessory update.
