F1225 fault in WEG CFW900 Drive
F1225 fault in WEG CFW900 Drive indicates a Slot B Temperature Sensor Hardware Configuration Error. This means the module’s physical DIP switches do not match the software parameters.
  • The sensor type selected by the accessory DIP switches does not match the sensor type configured by parameters.
  • DIP switch configured incorrectly. Check the CFW900-TEMP-01 accessory guide.
  • “Sensor Type” parameter is incorrectly configured (refer to C5.2.6.1).
Check the physical DIP switch settings on the CFW900-TEMP-01 module. Ensure they correspond directly to the parameter configuration described in section C5.2.6.1.
