F1401 fault in WEG CFW900 Drive indicates a Slot D Initialization Error. This means the module in Slot D failed to initialize due to a resource conflict with another installed accessory.
- The required operational resource is already occupied/allocated by another accessory.
- For communication accessories, only one node/accessory of each network type can be active on the inverter at a time.
Review Slot D accessory layouts. Ensure only one module is configured for each type of network protocol on the inverter at any time.
