F1501 fault in WEG CFW900 Drive
F1501 fault in WEG CFW900 Drive indicates a Slot E Initialization Error. This means the module in Slot E failed to initialize due to a resource conflict with another installed accessory.
  • The required operational resource is already occupied/allocated by another accessory.
  • For communication accessories, only one node/accessory of each network type can be active on the inverter at a time.
Review Slot E accessory layouts. Ensure only one module is configured for each type of network protocol on the inverter at any time.
