F176 fault in WEG CFW900 Drive
F176 fault in WEG CFW900 Drive indicates an Internal Fan Speed Fault. This means one of the internal electronic cooling fans is failing to reach its commanded speed.
Internal fan 2 speed fault.
  • Dirt on the fan blades and rolling bearings.
  • Defective fan.
  • Defective fan power supply connection.
Clean fan blades and secure connections. Replace if mechanically failed.
