F185 fault in WEG CFW900 Drive
F185 fault in WEG CFW900 Drive indicates Pre-charge Protection. This means the main relay that bypasses the soft-start resistors failed to close, often due to an input phase loss.
It indicates pre-charge contactor fault.
  • Defective pre-charge contactor.
  • Command fuse open.
  • Phase loss at input L1/R or L2/S.
Check pre-charge contactor and loop fuses. Verify incoming input phases.
