F30002 fault in siemens sinamics V90 drive indicates a DC link overvoltage. This means the internal DC bus voltage spiked too high, typically caused by rapid motor deceleration regenerating too much energy back into the drive.
The power unit has detected overvoltage in the DC link.
- Motor regenerates too much energy.
- Device connection voltage too high.
- Line phase interrupted.
- Increase the ramp-down time.
- Activate the DC link voltage controller.
- Use a braking resistor.
- Increase the current limit of the infeed or use a larger module.
- Check the device supply voltage.
- Check the line supply phases.
