F30004 fault in siemens sinamics V90 drive
F30004 fault in siemens sinamics V90 drive indicates Drive heat sink overtemperature. This means the power module’s heat sink is dangerously hot, usually due to a failed cooling fan, poor ventilation, or continuous overload.
The temperature of the power unit heat sink has exceeded the permissible limit value.
  • Insufficient cooling, fan failure.
  • Overload.
  • Surrounding temperature too high.
  • Pulse frequency too high.
  • Check whether the fan is running.
  • Check the fan elements.
  • Check whether the surrounding temperature is in the permissible range.
  • Check the motor load.
  • Reduce the pulse frequency if this is higher than the rated pulse frequency.
