F30027 fault in siemens sinamics V90 drive indicates a Precharging DC link time monitoring failure. This means the internal DC bus could not charge up to the required voltage within the expected timeframe, often due to a low supply voltage or a damaged pre-charge resistor.
The power unit DC link was not able to be pre-charged within the expected time.
- There is no line supply voltage connected.
- The line contactor/line side switch has not been closed.
- The line supply voltage is too low.
- The pre-charging resistors are overheated as there were too many pre-charging operations per time unit.
- The pre-charging resistors are overheated as the DC link capacitance is too high.
- The pre-charging resistors are overheated.
- The pre-charging resistors are overheated as the line contactor was closed during the DC link fast discharge through the Braking Module.
- The DC link has either a ground fault or a short-circuit.
- The pre-charging circuit is possibly defective.
Check the line supply voltage at the input terminals.
