F31110 fault in Siemens V70 Drive indicates a Serial communications error. This means the drive cannot correctly read data from the absolute encoder due to a protocol transfer failure.
Serial communication protocol transfer error between the encoder and evaluation module.
- Check the encoder cable and shielding connection.
- Replace the motor.
