F31112 fault in siemens sinamics V90 drive
F31112 fault in siemens sinamics V90 drive indicates an Error bit set in the serial protocol. This means the absolute encoder is actively broadcasting an internal error code to the drive over the serial connection.
The encoder sends a set error bit via the serial protocol.
  • Contact the Hotline.
